Aller au contenu principal
HP Mini 110-3131dx Memory Card Replacement
aarondcollege
aarondcollege et 4 autres contributeurs
Dernière mise à jour le February 24, 2017
1 minute
Facile
Nécessite plus d'images
Étudiant en action
Meilleure introduction
This is a step by step guide to help you replace the memory card for the HP Mini 110-3131dx in order to increase the laptop's performance.
Ce dont vous avez besoin
Outils
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Memory Card Replacement, Back Cover: étape 2, image 1 de 2 HP Mini 110-3131dx Memory Card Replacement, Back Cover: étape 2, image 2 de 2
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Memory Card Replacement, Memory Card: étape 3, image 1 de 3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: étape 3, image 2 de 3 HP Mini 110-3131dx Memory Card Replacement, Memory Card: étape 3, image 3 de 3
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  3. HP Mini 110-3131dx Memory Card Replacement: étape 4, image 1 de 2 HP Mini 110-3131dx Memory Card Replacement: étape 4, image 2 de 2
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
To install the new memory card, follow these instructions in reverse order.
aarondcollege
Membre depuis le 10/06/16
1 312 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 2-4, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 membres
1 commentaire de tutoriel
what ram she using hp mini
ASKAR MALAYA - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 19
Total : 743
