Aller au contenu principal
HP Mini 110-3131dx Touchpad Replacement
aarondcollege
aarondcollege et 11 autres contributeurs
Dernière mise à jour le March 19, 2025
45 minutes
Modérée
Nécessite plus d'images
Étudiant en action
Outils incorrects
This guide provides direction for learning how to replace the touchpad for the HP Mini 110-3131dx. In order to do so, you will need an iFixit Opening Tool, a Phillips #1 Screwdriver, and a Phillips #0 Screwdriver. Before you start, be sure to power off your HP Mini 110-3131dx. Best of luck!
Ce dont vous avez besoin
Outils
Afficher plus…
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Touchpad Replacement, Keyboard: étape 2, image 1 de 1
    • Remove the three black screws marked by the keyboard symbol using a Phillips #1 screwdriver.
  2. HP Mini 110-3131dx Touchpad Replacement: étape 3, image 1 de 3 HP Mini 110-3131dx Touchpad Replacement: étape 3, image 2 de 3 HP Mini 110-3131dx Touchpad Replacement: étape 3, image 3 de 3
    • Turn the laptop upright and open it.
    • Disconnect the clips located around the perimeter of the keyboard.
    • Slide the iFixit opening tool between the top edge of the keyboard and the plastic bezel.
    • Start either above the esc key or the delete key.
    • Pull the keyboard with your fingers until it comes out on both sides.
    • Be careful not to pull the keyboard out too fast. There is a fragile ribbon cable that attaches to the motherboard behind the keyboard.
  3. HP Mini 110-3131dx Touchpad Replacement: étape 4, image 1 de 1
    • Tilt the keyboard toward you to reveal the ribbon cable.
    • Lift up the black tab on top of the keyboard ribbon cable to release the ribbon cable.
    • Pull the ribbon cable out of its container.
  4. HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: étape 5, image 1 de 2 HP Mini 110-3131dx Touchpad Replacement, Keyboard Bezel: étape 5, image 2 de 2
    • Remove the six black screws around the perimeter of the laptop using a Phillips #1 screwdriver.
    • Be sure to keep track of which screws go where as they are not all the same size.
    • Flip the laptop over and remove the six black screws.
  5. HP Mini 110-3131dx Touchpad Replacement: étape 6, image 1 de 2 HP Mini 110-3131dx Touchpad Replacement: étape 6, image 2 de 2
    • Using your fingernail or the iFixit opening tool, flip the black tab up to release the ribbon cable that connects the touchpad and motherboard.
    • Disconnect the red and black wires from the motherboard on the left-hand side of the bezel using your fingernail or iFixit opening tool.
  6. HP Mini 110-3131dx Touchpad Replacement: étape 7, image 1 de 1
    • Lift the keyboard bezel from the back end and slide the iFixit opening tool around the perimeter of the bezel until it is fully released.
  7. HP Mini 110-3131dx Touchpad Replacement, Touchpad: étape 8, image 1 de 3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: étape 8, image 2 de 3 HP Mini 110-3131dx Touchpad Replacement, Touchpad: étape 8, image 3 de 3
    • Turn the keyboard so that the touchpad is close to you.
    • Detach the ribbon cable from the connector on the touchpad circuit board using your fingernail or an opening tool.
    • Remove the four 2.9 mm screws from the bracket using a Phillips #0 screwdriver.
    • Remove the touchpad from the top of the keyboard bezel on the touch-sensitive side.
aarondcollege
Membre depuis le 10/06/16
1 312 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 2-4, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 736
