Aller au contenu principal
HP Pavilion 17-g192dx Screen Replacement
Dominic Perito
Dominic Perito et 3 autres contributeurs
Dernière mise à jour le December 16, 2019
25 - 30 minutes
Difficile
Meilleure introduction
This Guide covers how to replace the 17.3 in display on the Hp Pavilion. Only replace if it is beyond repair and required.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: étape 1, image 1 de 3 HP Pavilion 17-g192dx Screen Replacement, Battery: étape 1, image 2 de 3 HP Pavilion 17-g192dx Screen Replacement, Battery: étape 1, image 3 de 3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Screen Replacement: étape 2, image 1 de 1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Screen Replacement: étape 3, image 1 de 2 HP Pavilion 17-g192dx Screen Replacement: étape 3, image 2 de 2
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: étape 4, image 1 de 2 HP Pavilion 17-g192dx Screen Replacement, Screen: étape 4, image 2 de 2
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
  5. HP Pavilion 17-g192dx Screen Replacement: étape 5, image 1 de 1
    • Remove the two 7mm screws with a Philips #00 screwdriver.
  6. HP Pavilion 17-g192dx Screen Replacement: étape 6, image 1 de 3 HP Pavilion 17-g192dx Screen Replacement: étape 6, image 2 de 3 HP Pavilion 17-g192dx Screen Replacement: étape 6, image 3 de 3
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
  7. HP Pavilion 17-g192dx Screen Replacement: étape 7, image 1 de 3 HP Pavilion 17-g192dx Screen Replacement: étape 7, image 2 de 3 HP Pavilion 17-g192dx Screen Replacement: étape 7, image 3 de 3
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
  8. HP Pavilion 17-g192dx Screen Replacement: étape 8, image 1 de 1
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
  9. HP Pavilion 17-g192dx Screen Replacement: étape 9, image 1 de 2 HP Pavilion 17-g192dx Screen Replacement: étape 9, image 2 de 2
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
3 autres ont terminé cette réparation.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 22
Total : 397
