Aller au contenu principal
HP Pavilion Notebook 15-ab293cl CPU Fan Replacement
John Carlo Barajas
John Carlo Barajas et 4 autres contributeurs
Dernière mise à jour le May 7, 2024
15 - 25 secondes
Modérée
The cooling fan is essential in order for your laptop to keep from overheating and for it to function at all. Being such an essential part of the laptop as a whole, it is absolutely necessary for it to be running at optimal conditions. Through thorough examination of this guide you will be fully able to access the cooling fan and replace it with ease.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: étape 1, image 1 de 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: étape 1, image 2 de 2
    • Start by flipping the laptop, revealing its back.
  2. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 2, image 1 de 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 2, image 2 de 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 2, image 3 de 3
    • Slide the tab marked with a lock/unlock symbol. The slide the other tab in order to release the battery.
  3. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 3, image 1 de 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 3, image 2 de 2
    • Once the battery is removed, unscrew and remove the both of the 7.5 mm screws off the black tabs using a PH1 screw driver. Then pry off the covers using the plastic opening tools.
  4. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 4, image 1 de 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 4, image 2 de 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 4, image 3 de 3
    • Remove all 16 size 3.5 mm screws with a PH1 screwdriver and pry the CD drive in order reveal one last screw that must be removed.
  5. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 5, image 1 de 1
    • Utilizing either a plastic or metal opening tool, begin prying the case from the laptop. Lastly, remove the remaining clips located on the back of the laptop.
  6. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 6, image 1 de 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 6, image 2 de 2
    • Once the laptop is fully open locate the cooling fan.
  7. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 7, image 1 de 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 7, image 2 de 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    • Utilizing a PH00 Screwdriver remove the two 3.5 mm screws detaining the cooling fan. Then use tweezers to remove the plug connecting the cooling fan to the mother board. Lastly remove the cooling fan.
5 autres ont terminé cette réparation.
John Carlo Barajas
Membre depuis le 09/10/18
229 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G2, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
very detailed. Thanks!
mrobinson29 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 28
Total : 1,332
