Aller au contenu principal
HP ProBook 4540s Keyboard Replacement
Amber Schindler
Amber Schindler et 6 autres contributeurs
Dernière mise à jour le May 24, 2018
5 minutes
Facile
Removing the keyboard will require removing the bottom door before turning it over to remove the keyboard. Be wary of any loose components when the laptop is turned right side up.
Ce dont vous avez besoin
Outils
  1. HP ProBook 4540s Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Keyboard Replacement, Bottom Door: étape 2, image 1 de 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Keyboard Replacement, Keyboard: étape 3, image 1 de 1
    • Remove four 6.0 mm Phillips PM2.5x6.0 screws.
  4. HP ProBook 4540s Keyboard Replacement: étape 4, image 1 de 1
    • Turn the computer over and position it right-side up in order and open the computer as far as possible.
  5. HP ProBook 4540s Keyboard Replacement: étape 5, image 1 de 1
    • Move the keyboard in a downward fashion towards the palm rest.
  6. HP ProBook 4540s Keyboard Replacement: étape 6, image 1 de 1
    • Lift the top of the keyboard at an angle and then gently pull it up and away from the palm rest.
    • Only pull the keyboard up enough to release it. The cable beneath the keyboard will still be attached to the system board.
  7. HP ProBook 4540s Keyboard Replacement: étape 7, image 1 de 1
    • Disconnect the keyboard cable by lifting the latch at the center of the system board.
    • Completely remove the keyboard.
16 autres ont terminé cette réparation.
Amber Schindler
Membre depuis le 10/26/16
1 042 Réputation
6 tutoriels rédigés
Équipe
UW Tacoma, Team 1-5, Rose Fall 2016 Membre de l'équipe UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 membres
6 tutoriels rédigés
2 commentaires de tutoriel
Precise and clear guide. Great Work!!!
Mario Mutale - Réponse
Easy to follow and a great help to get the job done. Thanks
d1211109 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 26
Total : 7,435
