Aller au contenu principal
HP ZBook 15 SSD Cache Replacement
Grant Terris
Grant Terris et 3 autres contributeurs
Dernière mise à jour le June 15, 2015
5 minutes
Facile
Solid state drives are much faster than hard disk drives, but are much more expensive. The ZBook 15 comes with a small solid state storage unit called a cache. If you want your computer to run faster, you can move your operating system from the disk drive to the solid state cache. This will greatly decrease the amount of time it takes for your computer to boot from its powered-down or sleep states. If you need to replace the solid state cache on your laptop, follow this guide!
Ce dont vous avez besoin
Outils
  1. HP ZBook 15 SSD Cache Replacement, Battery: étape 1, image 1 de 2 HP ZBook 15 SSD Cache Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 SSD Cache Replacement, Back Cover: étape 2, image 1 de 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 SSD Cache Replacement, SSD Cache: étape 3, image 1 de 2 HP ZBook 15 SSD Cache Replacement, SSD Cache: étape 3, image 2 de 2
    • Remove the two 3 mm screws with a Phillips #0 screwdriver.
    • Remove the Solid State Cache by pulling the module up and out.
6 autres ont terminé cette réparation.
Grant Terris
Membre depuis le 01/30/15
2 834 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 8-43, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 membres
15 tutoriels rédigés
2 commentaires de tutoriel
Does it create a seprate volume drive by inserting the mSata SSD to install Operating System on it?
Reza Sajedi - Réponse
Remember, this machine is from 2013, a time when SSDs were still hella expensive! That’s why the mSATA drive is refered to as a “cache” drive: they were so small they were only good for that. A stock, untouched Zbook g1/g2 might still come with a small (32GB) mSATA SSD configured as cache in the OS.
That doesn’t mean you can’t use the mSATA drive as your main OS drive, and that’s what I’ve been doing for years without a hint of trouble. You can easily find a high capacity mSATA SSD and put your OS and I/O-intensive programs on it. The Zbook will purr along nicely.
Luis Alejandro Araúz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 53
Total : 12,378
