HTC One Max Rear Facing Camera Replacement
Introduction
Passez à l'étape 1You will learn how to replace your rear camera in this guide.
Ce dont vous avez besoin
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
Disconnect the cable near the volume buttons.
The orange circle in line with the 4 other red circles down the RH side (as shown) in the photo should be red also, as this shows a screw, not the cable (which is by the volume buttons).
Hey Huey,
Nice catch! This has now been fixed.
Outil utilisé dans cette étape :Tweezers$4.99
Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
What does the orange circle refer to, as the text is a duplicate of the red circle description (and the highlighted item isn't connected with the three gate connectors)?
I think the orange circle refers to a 4th gate connector which needs to be disconnected.
Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
Pull out ribbon cable.
Peel back infrared sensor.
the orange circle pointed at ribbon cable while the red pointed at infrared sensor
8 autres ont terminé cette réparation.
1 commentaire de tutoriel
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
