HTC Radar 4G Casing Replacement
Introduction
Passez à l'étape 1Replace a dented, cracked, or scratched casing on your HTC Radar 4G. If your casing is dented, your LCD is most likely damaged too. It would be best if you also replaced your LCD, to restore full functionality to your phone.
Ce dont vous avez besoin
Remove the 4 silver T5 Torx screws from the motherboard protector.
Carefully slide off the motherboard protector.
Gently push on the motherboard until the display starts to come out of its frame.
Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
