Aller au contenu principal
Harman Kardon Invoke Power Port Replacement
Angel A. Grageda
Angel A. Grageda et 7 autres contributeurs
Dernière mise à jour le June 30, 2021
10 minutes
Facile
This guide will help you to replace the power port of Harman Kardon Invoke. You may replace the power port if you faced a weak port that will affect the efficiency of the Invoke or a broken/old port that prevents the invoke from connecting to power. By replacing the power port, the Invoke should be connecting to the power perfectly.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Harman Kardon Invoke Power Port Replacement, Power Port: étape 1, image 1 de 2 Harman Kardon Invoke Power Port Replacement, Power Port: étape 1, image 2 de 2
    • Use a metal spudger to remove the rubber base.
  2. Harman Kardon Invoke Power Port Replacement: étape 2, image 1 de 2 Harman Kardon Invoke Power Port Replacement: étape 2, image 2 de 2
    • Use a T10 Torx screwdriver to remove the four 14 mm screws.
  3. Harman Kardon Invoke Power Port Replacement: étape 3, image 1 de 2 Harman Kardon Invoke Power Port Replacement: étape 3, image 2 de 2
    • Grip the bottom firmly and wiggle upwards to remove it.
    Firmly grip the bottom
    Craig Blackwell - Réponse
  4. Harman Kardon Invoke Power Port Replacement: étape 4, image 1 de 3 Harman Kardon Invoke Power Port Replacement: étape 4, image 2 de 3 Harman Kardon Invoke Power Port Replacement: étape 4, image 3 de 3
    • Use a T10 Torx screwdriver to remove two 10 mm screws from the board that is attached to the ports.
    • Pull the board up lightly.
  5. Harman Kardon Invoke Power Port Replacement: étape 5, image 1 de 2 Harman Kardon Invoke Power Port Replacement: étape 5, image 2 de 2
    • Pull the cable to disconnect the board from the device.
    • To replacement the service port, you will have to replace the whole board that the port is attached to.
Angel A. Grageda
Membre depuis le 10/02/18
686 Réputation
4 tutoriels rédigés
1 commentaire de tutoriel
can I buy that power port circuit board from HK direct?
crokeclan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 19
Total : 565
