Heyday Wireless Bluetooth Speaker 9979 Battery Replacement
Introduction
Passez à l'étape 1This wireless speaker is small so be gentle with it. Replacing this battery is not hard at all. Just follow the instructions correctly and you should be able to get it done. Only part where you may need to use a little more force is using the metal spudger in the steps that require it.
Ce dont vous avez besoin
Remove the four bezels from the speaker's back cover.
Outil utilisé dans cette étape :Tweezers$4.99
Using the nylon tipped tweezers, remove the motherboard carefully. It is recommended to grab the motherboard in the middle as there are no big buttons on it.
Detail Is needed here since the motherboard is fragile, for instance is their a specific area we should grab it from or can we just grab it from an place. In other words, more specific details about how we should take out the motherboard safely.
The middle part of the motherboard does not any buttons in the middle so it is recommended to grab it there.
4 commentaires de tutoriel
The grammar could be improved by simplifying the steps (not using too many words or try separating into multiple bullet points) and avoiding the use of ambiguous pronouns (it).
Will do, thanks!
There are a lot of images and some are the same.
The description of each tool needed was a very useful touch.
