Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Factory Reset an iPhone
  1. How to Factory Reset an iPhone, Navigate to the Settings Menu.: étape 1, image 1 de 3 How to Factory Reset an iPhone, Navigate to the Settings Menu.: étape 1, image 2 de 3 How to Factory Reset an iPhone, Navigate to the Settings Menu.: étape 1, image 3 de 3
    • Select the Settings App.
    • If you are unsure where your Settings App is, swipe all the way to the left and use the Search function to pull it up for you.
  2. How to Factory Reset an iPhone, Find Reset in Settings: étape 2, image 1 de 2 How to Factory Reset an iPhone, Find Reset in Settings: étape 2, image 2 de 2
    • Select General. It will likely be along the bottom edge of the first screen.
    • Scroll to the bottom of the following menu. Tap the Reset option. Depending on the version of iOS your phone is running it may alternatively read Transfer or Reset iPhone.
  3. How to Factory Reset an iPhone, Reset the iPhone: étape 3, image 1 de 3 How to Factory Reset an iPhone, Reset the iPhone: étape 3, image 2 de 3 How to Factory Reset an iPhone, Reset the iPhone: étape 3, image 3 de 3
    • Select the Erase All Content and Settings option.
    • The iPhone will confirm what information will be removed during this process. Click Continue at the bottom of the screen.
    • It will confirm one final time that you want to Erase it. It may ask for your Apple ID password to authenticate.
  4. How to Factory Reset an iPhone, Wait: étape 4, image 1 de 1
    • The phone will restart to an Apple logo. A progress bar will appear and fill as the the phone removes data and reinstalls the Operating System.
    • It may restart a few times during the process, or appear to be off for longer than usual between restarts.
    • After patiently waiting, the device will restart to the Setup Assistant allowing you to start configuration from scratch or someone else to do the same.
The iPhone Setup Assistant will walk you through reactivating and configuring your device. If this reset was done to rule out a software problem, restore your data later. Be sure your issue is resolved without all the additional apps, data and settings changes.
11 autres ont terminé cette réparation.
Alisha C
Membre depuis le 12/04/20
41 983 Réputation
9 tutoriels rédigés
Équipe
LGBTQ Technicians Membre de l'équipe LGBTQ Technicians
Community
54 membres
91 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 147
30 derniers jours : 667
Total : 8,647
