Aller au contenu principal
How to Open the Fitbit Charge 2
Adriana Zwink
Adriana Zwink et un autre contributeur
Dernière mise à jour le May 24, 2024
10 - 15 minutes
Modérée
Use this guide to open your Fitbit Charge 2 for repairs.
Ce dont vous avez besoin
Outils
  • iOpener
    iOpener
  • iSesamo Opening Tool
  • Spudger
    Spudger
Afficher plus…
  1. How to Open the Fitbit Charge 2, Remove the watch band: étape 1, image 1 de 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. How to Open the Fitbit Charge 2, Heat the touch screen: étape 2, image 1 de 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assemly.
  3. How to Open the Fitbit Charge 2, Slide along the left edge: étape 3, image 1 de 3 How to Open the Fitbit Charge 2, Slide along the left edge: étape 3, image 2 de 3 How to Open the Fitbit Charge 2, Slide along the left edge: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. How to Open the Fitbit Charge 2, Slide along the bottom edge: étape 4, image 1 de 2 How to Open the Fitbit Charge 2, Slide along the bottom edge: étape 4, image 2 de 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. How to Open the Fitbit Charge 2: étape 5, image 1 de 3 How to Open the Fitbit Charge 2: étape 5, image 2 de 3 How to Open the Fitbit Charge 2: étape 5, image 3 de 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. How to Open the Fitbit Charge 2: étape 6, image 1 de 2 How to Open the Fitbit Charge 2: étape 6, image 2 de 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. How to Open the Fitbit Charge 2: étape 7, image 1 de 2 How to Open the Fitbit Charge 2: étape 7, image 2 de 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. How to Open the Fitbit Charge 2: étape 8, image 1 de 2 How to Open the Fitbit Charge 2: étape 8, image 2 de 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. How to Open the Fitbit Charge 2: étape 9, image 1 de 2 How to Open the Fitbit Charge 2: étape 9, image 2 de 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. How to Open the Fitbit Charge 2: étape 10, image 1 de 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
Opening didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Membre depuis le 12/18/19
56 807 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
19 665 tutoriels rédigés
1 commentaire de tutoriel
How do I get the daughterboard out?
Pospesel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 86
Total : 5,950
