Aller au contenu principal
How to Open the Samsung Galaxy Watch4
Adriana Zwink
Adriana Zwink et 2 autres contributeurs
Dernière mise à jour le December 21, 2024
5 - 10 minutes
Modérée
Use this guide to remove the back cover of the Samsung Galaxy Watch4.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. How to Open the Samsung Galaxy Watch4, Power down your Galaxy Watch4: étape 1, image 1 de 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Samsung Galaxy Watch4, Unscrew the back cover: étape 2, image 1 de 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
  3. How to Open the Samsung Galaxy Watch4, Wedge open the back cover: étape 3, image 1 de 2 How to Open the Samsung Galaxy Watch4, Wedge open the back cover: étape 3, image 2 de 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. How to Open the Samsung Galaxy Watch4, Disconnect the sensor flex cable: étape 4, image 1 de 2 How to Open the Samsung Galaxy Watch4, Disconnect the sensor flex cable: étape 4, image 2 de 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. How to Open the Samsung Galaxy Watch4, Remove the back cover: étape 5, image 1 de 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
Adriana Zwink
Membre depuis le 12/18/19
57 053 Réputation
167 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
19 995 tutoriels rédigés
7 commentaires de tutoriel
the glass broke on the back of my watch 4 and i have managed to get all the shards and seal out without damaging anything, but I am having trouble finding remplacement glass for the sensor in canada
Champy Ton - Réponse
It just suddenly turned off and won't turn on it just vibrates in sequences, i don't know what to do.
Salim Juma - Réponse
I am having a real tough time unscrewing the screws despite having the right screwdriver. It is like they are stuck on.
Mishaal Jadunundon - Réponse
hello, I replaced the sensor but once I connect the flex cable to the motherboard it just doesn't work.
meaning that the sensor is not working (even no green light on the back) but the wireless charging is working.
I tried to disconnect and reconnect again but still no way to let the sensore work.
is there anything that must be reset softwarewise in order the watch can recognize the sensor?
Or probably the flex cable is not working properly?
thanks in advance
Daniele - Réponse
I am having the same exact issue. Did you ever find a solution?
Jasmine -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 62
30 derniers jours : 286
Total : 11,136
