Aller au contenu principal
Inspiron 7359 2-in-1 Screen Replacement
Dominique
Dominique et 7 autres contributeurs
Dernière mise à jour le March 23, 2025
15 minutes
Modérée
Étudiant en action
Meilleure introduction
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with a 13.3-inch (33.78 cm) – HD (1366×768), IPS touchscreen. Consider replacing the screen if
  1. The screen has dead pixels.
  2. The screen is flickering.
  3. The is screen is cracked.
  4. You simply want to upgrade it.
It's a little intimidating to replace an LCD-touchscreen, but if you have the replacement screen, the right tools, and you follow these instructions carefully, you're gonna have your computer looking good very soon. The most significant tool will probably be the spludger/opening pick that'll let you separate the screen and screen backing. If you need to get the tool, iFixit has your back with that too. There's little danger once you power off and disconnect the computer. Just be careful with the screen during replacement, because it is fragile to detach and to install. Make sure not to cut yourself on anything either. The screen isn't particularly sharp, but if it's cracked, it may have edges. This guide will show you what parts to take special care with.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Inspiron 7359 2-in-1 Screen Replacement, Bottom Case: étape 1, image 1 de 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Screen Replacement: étape 2, image 1 de 2 Inspiron 7359 2-in-1 Screen Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Screen Replacement: étape 3, image 1 de 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Screen Replacement: étape 4, image 1 de 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Screen Replacement, Screen: étape 5, image 1 de 1
    • Using a spudger or opening pick, carefully pry in between the screen and the screen backing.
    • After opening the LCD Screen, slowly and carefully open the laptop so the front of the screen touches the keyboard.
  6. Inspiron 7359 2-in-1 Screen Replacement: étape 6, image 1 de 1
    • Slowly peel back the tape that is attached to the screen itself.
    • Once the tape is removed, gently disconnect the attached cables.
  7. Inspiron 7359 2-in-1 Screen Replacement: étape 7, image 1 de 1
    • Carefully disconnect the attached cable.
    • Once you remove the attached cable, gently lift up the LCD panel.
2 autres ont terminé cette réparation.
Dominique
Membre depuis le 08/26/19
251 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team S1-G3, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 11
Total : 524
