JBL Charge 4 Passive Bass Radiators Replacement
Introduction
Passez à l'étape 1The passive bass radiators significantly help to improve the sound quality of the JBL Charge 4 by amplifying the deep pitches in sound. They also keep the speaker waterproof by sealing out water from the sides. This guide will show you how to replace the bass radiators if the bass of your speaker is not sounding as good as it once was, or if you need to gain access to the inside of the speaker.
Ce dont vous avez besoin
Flip your speaker over and insert the plastic opening tool into the slit on the grille.
Pry away from yourself towards the back of the speaker to release the clip.
Repeat this process for the clip on the other side.
Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
Repeat this process on the other clips around the radiator to release it from the frame.
9 autres ont terminé cette réparation.
5Commentaires sur le guide
Exactly where are supposed to get parts for this, do you suppose !?
It says it on the top of the introduction
Hi do you hany any suggestion on where to buy the passive radiators?
Were can i get the main cover from can you help please and the subwoofers
Yo tengo la charge 4 y se me rompió uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
