Aller au contenu principal
JBL Pulse 3 Outside Casing Replacement
Kaitlyn Greenfield
Kaitlyn Greenfield et 2 autres contributeurs
Dernière mise à jour le December 23, 2020
10 - 15 minutes
Modérée
Nécessite plus d'images
The outside casing of the JBL Pulse 3 is the top portion of the device above the speaker grill. In order to take this part off the device, you will need to have removed the speaker grill first. For more information regarding troubleshooting, please visit our Troubleshooting Page.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. JBL Pulse 3 Outside Casing Replacement, Speaker Grill: étape 1, image 1 de 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Outside Casing Replacement: étape 2, image 1 de 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Outside Casing Replacement: étape 3, image 1 de 2 JBL Pulse 3 Outside Casing Replacement: étape 3, image 2 de 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Outside Casing Replacement, Outside Casing: étape 5, image 1 de 2 JBL Pulse 3 Outside Casing Replacement, Outside Casing: étape 5, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    #00 not required, successfully opened with PH#1
    Stephen Hoefler - Réponse
  5. JBL Pulse 3 Outside Casing Replacement: étape 6, image 1 de 2 JBL Pulse 3 Outside Casing Replacement: étape 6, image 2 de 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    Ca I Specifically buy the top ring
    Julian Cruz - Réponse
    I've the same concern as the comment above, can I buy the top ring separately?
    Yousef - Réponse
    Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
    Kusala Kumsinda - Réponse
    Is there any other place to get this part? It doesnt ship to the UK
    Amelia - Réponse
  6. JBL Pulse 3 Outside Casing Replacement: étape 7, image 1 de 2 JBL Pulse 3 Outside Casing Replacement: étape 7, image 2 de 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Outside Casing Replacement: étape 8, image 1 de 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Outside Casing Replacement: étape 9, image 1 de 2 JBL Pulse 3 Outside Casing Replacement: étape 9, image 2 de 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
    Richard Devos - Réponse
  9. JBL Pulse 3 Outside Casing Replacement: étape 10, image 1 de 2 JBL Pulse 3 Outside Casing Replacement: étape 10, image 2 de 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Outside Casing Replacement: étape 11, image 1 de 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
4 autres ont terminé cette réparation.
Kaitlyn Greenfield
Membre depuis le 09/20/18
1 188 Réputation
6 tutoriels rédigés
3 commentaires
Wherr can I get or buy top ring for Pulse 3?
Mark Christian Mariñas - Réponse
Please see our device page with the link to the manufacturer’s website. You should be able to find it there.
Kaitlyn Greenfield - Réponse
I have one of these speakers, and as the delicate outer shell broke it seems nearly impossible to find a replacement…
Any chance to get spare parts in Europe? Thank you.
Raffaele T. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 37
Total : 3,406
