Aller au contenu principal
Kindle Touch 3G Card Housing Replacement
Adam Yerly
Adam Yerly et 3 autres contributeurs
Dernière mise à jour le December 29, 2015
5 minutes
Facile
Next to the battery is the 3G unit. However, in the
models that are WiFi only, there will instead be a plastic placeholder instead. The replacement instructions for both are identical.
Ce dont vous avez besoin
Outils
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Afficher plus…
Vidéo d'introduction
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: étape 1, image 1 de 3 Kindle Touch 3G Card Housing Replacement, Back Cover: étape 1, image 2 de 3 Kindle Touch 3G Card Housing Replacement, Back Cover: étape 1, image 3 de 3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - Réponse
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - Réponse
  2. Kindle Touch 3G Card Housing Replacement: étape 2, image 1 de 2 Kindle Touch 3G Card Housing Replacement: étape 2, image 2 de 2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - Réponse
  3. Kindle Touch 3G Card Housing Replacement, Battery: étape 3, image 1 de 3 Kindle Touch 3G Card Housing Replacement, Battery: étape 3, image 2 de 3 Kindle Touch 3G Card Housing Replacement, Battery: étape 3, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: étape 4, image 1 de 3 Kindle Touch 3G Card Housing Replacement: étape 4, image 2 de 3 Kindle Touch 3G Card Housing Replacement: étape 4, image 3 de 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: étape 5, image 1 de 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: étape 5, image 2 de 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: étape 5, image 3 de 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
    The 3G model has an antenna connector near the top left on the underside.
    Chad Wade Day, Jr. - Réponse
3 autres ont terminé cette réparation.
Adam Yerly
Membre depuis le 01/20/15
1 982 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 19-5, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 membres
8 tutoriels rédigés
2 commentaires de tutoriel
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Réponse
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 25
Total : 2,310
