Aller au contenu principal
KitchenAid Professional 600 Worm Gear Replacement
Luke
Luke et un autre contributeur
Dernière mise à jour le September 2, 2023
Aucune estimation
Facile
Meilleure introduction
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. KitchenAid Professional 600 Worm Gear Replacement, Top Cover: étape 1, image 1 de 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Maybe start with unplugging it ?
    Ryan F - Réponse
  2. KitchenAid Professional 600 Worm Gear Replacement: étape 2, image 1 de 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Worm Gear Replacement: étape 3, image 1 de 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Worm Gear Replacement, Gear Housing Cover: étape 4, image 1 de 1
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
  5. KitchenAid Professional 600 Worm Gear Replacement: étape 5, image 1 de 1
    • Take off the black housing cover.
  6. KitchenAid Professional 600 Worm Gear Replacement, Worm Gear: étape 6, image 1 de 1
    • Remove the Worm Gear.
    • The Worm Gear is the part that is lying horizontal.
    • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
    Before replacing part, make sure you remove all the old grease (the black gunk). It could contain metal shards that will quickly wear down gears. I used a 50% alcohol and a lot of rags and cotton swabs (Q-Tips®). Make sure everything is dry before placing new food-grade grease.
    mommarosie - Réponse
    How do I know the code of this part?
    Thuy Truong - Réponse
    Kirtchen Aid Store Part Nr. KitchenAid W10112253 481201230741
    VauWeh -
    This part probably fits, but you have to check carefully.
    VauWeh -
    The parts nr is not correct! Does anybody have the correct nr?
    Dr. Crimper -
    Is there a part number for the two metal stand off guide things on the worm gear?
    Kunwardip Mooker - Réponse
9 autres ont terminé cette réparation.
Luke
Membre depuis le 04/11/16
1 380 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-4, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 membres
18 tutoriels rédigés
1 commentaire de tutoriel
No tiene ningún tornillo a los lado eso es mentira
Guillermo Perez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 100
Total : 20,640
