Aller au contenu principal
Kodak EasyShare M1033 LCD Screen Assembly Replacement
ntuong1117
ntuong1117 et 2 autres contributeurs
Dernière mise à jour le June 18, 2024
15 - 25 minutes
Modérée
Tutoriel étudiant vedette
The Kodak EasyShare M1033 device, released in 2008, is prone to sustaining scratches or imperfections on the LCD due to faulty maintenance or usage. Fortunately, it is moderately easy to replace the screen. This guide provides step-by-step instructions on how to successfully replace the LCD screen assembly of your Kodak EasyShare M1033 camera.
The LCD screen is crucial for any camera as it displays your photos and settings. A faulty screen can make it difficult to view the content on your camera and won't give you the best experience you deserve.
Although it’s unlikely to receive an electric shock from the capacitors when repairing a digital camera, it is still possible. Therefore, taking precautionary measures by removing the battery before you begin the repair.
Here is the link to the Kodak EasyShare M1033/M2008 manual if you need further assistance.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: étape 1, image 1 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: étape 1, image 2 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement, LCD Screen Assembly: étape 1, image 3 de 3
    • Ensure that the camera is powered off.
    • Turn the camera over so the battery compartment is facing up.
    • Place your thumb on the embossed surface of the battery latch, and push down and out until the latch releases.
    • Push down on the orange tab to release and remove the batteries.
    • Close the latch.
    • Let the camera sit for a minute to avoid electrical shock.
  2. Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 2, image 1 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 2, image 2 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 2, image 3 de 3
    • Use a Phillips #00 screwdriver to remove six screws along the edge of the camera.
    • There are two screws next to the battery compartment
    • Two screws on the left side
    • Two screws on the right side
  3. Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 3, image 1 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 3, image 2 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 3, image 3 de 3
    • Use a spudger or your fingernail to pry the plastic case covering the LCD screen from the back of the camera.
  4. Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 4, image 1 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 4, image 2 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 4, image 3 de 3
    • Use a spudger to gently pry the LCD assembly and move it to reveal a ZIF connector.
    • Don't pull it off as it is connected by a ribbon cable.
    • Use your fingernail or the tip of the spudger to flip up the small locking flap.
    • Gently pull the cable out.
    • Remove the old LCD screen assembly.
  5. Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 5, image 1 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 5, image 2 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 5, image 3 de 3
    • Carefully insert the ribbon cable of the new LCD screen assembly into the ZIF connector and securely flip the lock down.
    • Ensure that the ribbon is secure.
    • Place the LCD screen assembly back into the original position.
  6. Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 6, image 1 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 6, image 2 de 3 Kodak EasyShare M1033 LCD Screen Assembly Replacement: étape 6, image 3 de 3
    • Place the back case on top of the new LCD screen.
    • Use the Phillips #00 screwdriver to replace the six screws along the edge of the camera that secure the back case.
    • Righty tighty.
ntuong1117
Membre depuis le 03/05/24
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 8-13, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 8-13, Grodsky Spring 2024
CSULA-GRODSKY-S24S8G13
2 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 30
Total : 218
