Aller au contenu principal
LG V50 ThinQ Battery Replacement
Tanmay Sonawane
Tanmay Sonawane et 3 autres contributeurs
Dernière mise à jour le December 28, 2023
15 - 30 minutes
Modérée
The phone battery may be old, the CPU may be overloaded, the battery is no longer holding charge, and/or the device operating temperature is too hot. Try closing out unused apps, maintaining a safe operating temperature, and enabling power saver mode.
Before using this guide, make sure to review the LG V50 ThinQ troubleshooting page to ensure there are no other options to save your battery.
If the battery needs to be replaced, this guide will help you replace the battery for your LG V50 ThinQ android phone. Make sure the device is powered off before replacing the battery.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. LG V50 ThinQ Battery Replacement, Battery: étape 1, image 1 de 3 LG V50 ThinQ Battery Replacement, Battery: étape 1, image 2 de 3 LG V50 ThinQ Battery Replacement, Battery: étape 1, image 3 de 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Battery Replacement: étape 2, image 1 de 3 LG V50 ThinQ Battery Replacement: étape 2, image 2 de 3 LG V50 ThinQ Battery Replacement: étape 2, image 3 de 3
    • Remove all twelve 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Battery Replacement: étape 3, image 1 de 3 LG V50 ThinQ Battery Replacement: étape 3, image 2 de 3 LG V50 ThinQ Battery Replacement: étape 3, image 3 de 3
    • Remove the two brackets.
  4. LG V50 ThinQ Battery Replacement: étape 4, image 1 de 2 LG V50 ThinQ Battery Replacement: étape 4, image 2 de 2
    • DO NOT attempt to remove the phone battery with a metallic/sharp prying object.
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Remove the battery by prying the underside of the battery and pulling upwards with the opening pick (shown in image 2).
    • Do not be too rough with the battery, as it is easy to dent/break into.
    • Now, place the new battery inside the slot, firmly pressing it into the space against the copper-colored heatsink on the bottom.
3 autres ont terminé cette réparation.
Tanmay Sonawane
Membre depuis le 10/30/23
262 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 72
Total : 1,345
