Aller au contenu principal
LG V50 ThinQ Screen Replacement
Ce dont vous avez besoin
  1. LG V50 ThinQ Screen Replacement, Screen: étape 1, image 1 de 3 LG V50 ThinQ Screen Replacement, Screen: étape 1, image 2 de 3 LG V50 ThinQ Screen Replacement, Screen: étape 1, image 3 de 3
    • Flip the phone over, making sure that the back of the phone is facing up.
    • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
  2. LG V50 ThinQ Screen Replacement: étape 2, image 1 de 2 LG V50 ThinQ Screen Replacement: étape 2, image 2 de 2
    • With the device facing down, remove all 12 1mm Phillips #000 screws.
    • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
  3. LG V50 ThinQ Screen Replacement: étape 3, image 1 de 3 LG V50 ThinQ Screen Replacement: étape 3, image 2 de 3 LG V50 ThinQ Screen Replacement: étape 3, image 3 de 3
    • Remove the two brackets covering the internal components.
  4. LG V50 ThinQ Screen Replacement: étape 4, image 1 de 2 LG V50 ThinQ Screen Replacement: étape 4, image 2 de 2
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
  5. LG V50 ThinQ Screen Replacement: étape 5, image 1 de 1
    • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
    • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
    • Carefully put the replacement screen into place.
Carlos Rivera
Membre depuis le 11/03/23
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 870
