Aller au contenu principal
LeapFrog LeapPad Ultra XDi USB Charge Port Replacement
Rachel Baker
Rachel Baker et 6 autres contributeurs
Dernière mise à jour le November 14, 2019
45 minutes
Difficile
This guide provides steps for replacing the USB charge port in the LeapFrog LeapPad Ultra XDi (model number 33300).
The USB charge port transmits power to charge the battery. When this part is not working properly the device may not power on or hold a charge. You should first try simple troubleshooting steps (like a hard rest, cleaning the port, or replacing the power cord) before replacing the port.
Step 10 requires you to desolder the charge port from the motherboard and solder a the replacement charge port. A new USB charge port is also required for this guide.
Before beginning, make sure to power down the device completely and disconnect it from any power source.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Battery: étape 1, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Battery: étape 1, image 2 de 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 2, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 2, image 2 de 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 3, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 3, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 3, image 3 de 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 4, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 4, image 2 de 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 5, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 5, image 2 de 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 6, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 6, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 6, image 3 de 3
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Use the Spudger to remove the glued down battery.
  7. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: étape 7, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: étape 7, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: étape 7, image 3 de 3
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 8, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 8, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 8, image 3 de 3
    • Unscrew the four 5.0 mm Phillips #0 screws securing the motherboard.
  9. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 9, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 9, image 2 de 2
    • Lift the motherboard up to expose the fourth ribbon cable underneath.
    • Flip up the locking clip to release the cable, and disconnect the cable from the connector.
  10. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 10, image 1 de 1
    • Locate the charging port on the side of the motherboard.
    • Use a soldering iron to desolder the five metal connections to the motherboard. Replace the USB charge port.
Rachel Baker
Membre depuis le 09/01/19
109 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 10
Total : 1,373
