Aller au contenu principal
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
ZFix
ZFix et 4 autres contributeurs
Dernière mise à jour le October 14, 2024
Aucune estimation
Facile
Tutoriel réalisé par la communauté
How to disassemble the device and replace / upgrade Hard Disk Drive with SSD, SO-DIMM memory modules, WiFi / Wireless card M.2 aka NGFF (Next Generation Form Factor) and CMOS Battery (Complementary Metal-Oxide-Semiconductor (CMOS), Real-Time Clock (RTC)).
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Vidéo d'introduction
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: étape 1, image 1 de 1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: étape 2, image 1 de 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: étape 2, image 2 de 2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: étape 3, image 1 de 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: étape 3, image 2 de 2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): étape 4, image 1 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): étape 4, image 2 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): étape 4, image 3 de 3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: étape 5, image 1 de 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: étape 5, image 2 de 2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: étape 6, image 1 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: étape 6, image 2 de 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: étape 6, image 3 de 3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: étape 7, image 1 de 1
    • That's all.
3 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
194 325 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
326 membres
1 686 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 29
Total : 7,779
