Aller au contenu principal
Lenovo Edge Thinkpad E431 Screen Replacement
Abdullah Muhammad Ashfaq Nadir
Abdullah Muhammad Ashfaq Nadir et 3 autres contributeurs
Dernière mise à jour le March 26, 2024
15 minutes
Modérée
This guide will show you how to replace the screen on a Lenovo ThinkPad Edge E431 laptop.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo Edge Thinkpad E431 Screen Replacement, Battery: étape 1, image 1 de 2 Lenovo Edge Thinkpad E431 Screen Replacement, Battery: étape 1, image 2 de 2
    • Remove the 2mm Phillips #00 screw from the battery cover.
    • Lift the battery cover out of its slot.
    Please use a #1 Phillips driver and not a #00.
    Steven Michael - Réponse
  2. Lenovo Edge Thinkpad E431 Screen Replacement: étape 2, image 1 de 1
    • Disconnect the battery cable.
  3. Lenovo Edge Thinkpad E431 Screen Replacement, Screen: étape 3, image 1 de 1
    • Use the pointed end of a spudger to remove the two screw covers from the bottom corners of the display.
    Also, if this is the E430, remove the two rubber bumpers at each upper corners to reveal two more M2 screws.
  4. Lenovo Edge Thinkpad E431 Screen Replacement: étape 4, image 1 de 1
    • Remove the two 2mm Phillips #00 screws found at the bottom corners of the display.
  5. Lenovo Edge Thinkpad E431 Screen Replacement: étape 5, image 1 de 1
    • Separate the front bezel from the display using the plastic opening tool.
  6. Lenovo Edge Thinkpad E431 Screen Replacement: étape 6, image 1 de 1
    • Remove the four 2mm Phillips #00 screws from the screen.
  7. Lenovo Edge Thinkpad E431 Screen Replacement: étape 7, image 1 de 2 Lenovo Edge Thinkpad E431 Screen Replacement: étape 7, image 2 de 2
    • Lay the screen flat on top of the keyboard.
  8. Lenovo Edge Thinkpad E431 Screen Replacement: étape 8, image 1 de 2 Lenovo Edge Thinkpad E431 Screen Replacement: étape 8, image 2 de 2
    • Peel up the adhesive tape to unlatch the metal retaining bracket on the display cable.
3 autres ont terminé cette réparation.
Équipe
USF Tampa, Team S3-G3, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S3-G3, Nance Spring 2018
USFT-NANCE-S18S3G3
4 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Where do I buy the screen
Link - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 1,728
