Aller au contenu principal
Lenovo ThinkPad T400s Keyboard Replacement
Morgan Montalvo
Morgan Montalvo et 6 autres contributeurs
Dernière mise à jour le December 6, 2023
15 minutes
Facile
This guide will show you how to replace the keyboard.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T400s Keyboard Replacement: étape 2, image 2 de 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: étape 3, image 1 de 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T400s Keyboard Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T400s Keyboard Replacement: étape 4, image 3 de 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T400s Keyboard Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T400s Keyboard Replacement: étape 5, image 3 de 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
2 autres ont terminé cette réparation.
Morgan Montalvo
Membre depuis le 04/14/15
652 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-18, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 33
Total : 1,573
