Aller au contenu principal
Lenovo ThinkPad T440p Keyboard Replacement
Christian Abad
Christian Abad et 2 autres contributeurs
Dernière mise à jour le November 29, 2023
6 minutes
Modérée
If keys are unresponsive or the whole keyboard is unresponsive you will most likely need to replace the keyboard for your Lenovo ThinkPad T440p. Replacing the keyboard can be quite tedious but will mainly consist of unscrewing screws and using your spudger to lift and remove cables. When removing the plastic cover, remove carefully.
Ce dont vous avez besoin
Pièces
Outils
  • Phillips #00 Screwdriver
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Lenovo ThinkPad T440p Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Keyboard Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: étape 2, image 2 de 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Keyboard Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: étape 3, image 2 de 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
  5. Lenovo ThinkPad T440p Keyboard Replacement: étape 5, image 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: étape 5, image 2 de 2
    • Don't remove the screws; just loosen them.
    • Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad T440p Keyboard Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement: étape 6, image 3 de 3
    • Use the spudger to lift the keyboard.
  7. Lenovo ThinkPad T440p Keyboard Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T440p Keyboard Replacement: étape 7, image 2 de 2
    • Turn the keyboard over.
  8. Lenovo ThinkPad T440p Keyboard Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement: étape 8, image 3 de 3
    • Use the spudger to detach the plastic protection.
  9. Lenovo ThinkPad T440p Keyboard Replacement: étape 9, image 1 de 3 Lenovo ThinkPad T440p Keyboard Replacement: étape 9, image 2 de 3 Lenovo ThinkPad T440p Keyboard Replacement: étape 9, image 3 de 3
    • Use the spudger to disconnect the cables.
    CARE !!!
    My T440p type 20AW-S0Y40T does not have a detacheable plug/ socket and so the keyboard a “soldered on” device is
    NOT DETACHEABLE in this way 21/08/20
    Fritz - Réponse
  10. Lenovo ThinkPad T440p Keyboard Replacement: étape 10, image 1 de 1
    • Remove the keyboard.
9 autres ont terminé cette réparation.
Christian Abad
Membre depuis le 03/20/19
1 530 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G5, Peak Spring 2019 Membre de l'équipe UMass Dartmouth, Team S6-G5, Peak Spring 2019
UMASSD-PEAK-S19S6G5
3 membres
9 tutoriels rédigés
1 commentaire de tutoriel
Thanks for the guide. I hate this part lol.
is it true if I slip and knock keys off, they can’t be lit in? I’m told this and it seems true :(
Josh Tree - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 59
Total : 7,847
