Aller au contenu principal
Lenovo ThinkPad T480s SSD Replacement
Alejandro Carranza
Alejandro Carranza et 4 autres contributeurs
Dernière mise à jour le October 15, 2024
10 - 25 minutes
Facile
This guide is to replace a broken or full solid-state drive in the Lenovo ThinkPad T480s laptop. A solid-state drive (SSD) is a storage device used to store data for the user and the computer. This device stores data like a USB flash drive. The difference is this device is installed within the computer and is a necessity for the computer to run. If the SSD is not working or not installed ,the computer will not boot. Therefore, if the SSD is not working it must be replaced.
The SSD should also be replaced if it is full. The SSD is full when there is no more space to save files or applications. If the SSD is full the user can save some space by deleting some unwanted items. If space cannot be made, then the SSD needs to be upgraded to one with a larger capacity.
There are several different types of SSDs so it may be difficult to determine which one to buy. For this fix, an SSD of type M.2. is required. This type is referring to a form factor. That just means it’s the shape of the device and how it connects to the computer. Therefore, if the SSD is not type M.2. it will not work for this laptop.
 It’s important to back up your current SSD if possible. Make sure you create a back up of your data before starting this fix.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad T480s SSD Replacement, SSD: étape 1, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement, SSD: étape 1, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement, SSD: étape 1, image 3 de 3
    • Turn off the laptop and disconnect the power cord.
    • Turn the laptop back on and press the F1 button repeatedly to access the BIOS menu.
    • The BIOS is built in software for the computer. For this fix we will just need to use it to disconnect the battery.
    • The battery needs to be disconnected to avoid electro-static discharge. This is static electricity from your body that can damage electronics.
  2. Lenovo ThinkPad T480s SSD Replacement: étape 2, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 2, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 2, image 3 de 3
    • Once in the BIOS menu, press the arrow keys to select the desired options from the menu.
    • First, press the right arrow to select the Config menu.
    • Next, press the down arrow to select the Power option.
    • Lastly, press the down arrow to select the Disable Built-in Battery option. The laptop will then shut off.
  3. Lenovo ThinkPad T480s SSD Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T480s SSD Replacement: étape 3, image 2 de 2
    • Flip the laptop upside down to access the back panel.
    • Loosen the six screws using the Phillips #0 screwdriver.
    • These screws are not removable.
  4. Lenovo ThinkPad T480s SSD Replacement: étape 4, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 4, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 4, image 3 de 3
    • Use an opening tool to gently pry the back panel away from the laptop.
    • Start from either side of the laptop. Work your way around until all sides are loose.
  5. Lenovo ThinkPad T480s SSD Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 5, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the screw attached to the SSD.
    • The SSD will pop out at 45 degree angle. Gently tug the SSD and it should come out smoothly.
  6. Lenovo ThinkPad T480s SSD Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 6, image 3 de 3
    • Line up the replacement SSD according to the pin pattern of the slot.
    • Gently push the SSD into the slot. Ensure it is fully inserted.
    • Use the screw from the previous step to secure the SSD to the motherboard.
  7. Lenovo ThinkPad T480s SSD Replacement: étape 7, image 1 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 7, image 2 de 3 Lenovo ThinkPad T480s SSD Replacement: étape 7, image 3 de 3
    • Align the back panel with the four hinges towards the battery side. Ensure the hinges are put in first when laying the back panel down.
    • Gently press on all sides so that it clicks into place. Then tighten the six screws with the Phillips #0 screwdriver to secure the back panel.
  8. Lenovo ThinkPad T480s SSD Replacement: étape 8, image 1 de 2 Lenovo ThinkPad T480s SSD Replacement: étape 8, image 2 de 2
    • Flip over the laptop, reconnect the power, cord and turn on the laptop.
    • The built-in battery will be reconnected automatically by sensing the power cord.
With the replacement of the SSD complete the computer needs Windows 10 to run. A new version of Windows 10 can be installed or data can be recovered through the backup.
7 autres ont terminé cette réparation.
Alejandro Carranza
Membre depuis le 05/11/20
331 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G6, O'Regan Summer 2020 Membre de l'équipe York University, Team S1-G6, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G6
1 membre
3 tutoriels rédigés
1 commentaire de tutoriel
Great tutorial -- thanks for posting, I recommend cloning the disk via a thunderbolt enclosure prior to installing, if you buy a Samsung SSD, you can use the SSD clone software for this they provide . Then install the drive -- with any luck it should boot right up.
Jason D'Rion - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 70
30 derniers jours : 398
Total : 22,719
