Aller au contenu principal
Lenovo ThinkPad T495s Screen Replacement
Ijhanne Holder
Ijhanne Holder et 9 autres contributeurs
Dernière mise à jour le June 19, 2024
5 - 10 minutes
Facile
This guide will show you how to safely remove the screen from the Lenovo ThinkPad T495s. Before embarking on this process, refer to the link below for troubleshooting monitor issues to avoid unnecessary changes. A screen may need to be removed due to a cracked screen, broken LCD, dysfunctional touch screen, or to access the hardware behind the monitor. To replace a screen, reverse the steps followed in the guide. Use caution when prying off the connections with an iFixit opening tool and tweezer to ensure no further damage.
Ce dont vous avez besoin
  1. Lenovo ThinkPad T495s Screen Replacement, Screen: étape 1, image 1 de 3 Lenovo ThinkPad T495s Screen Replacement, Screen: étape 1, image 2 de 3 Lenovo ThinkPad T495s Screen Replacement, Screen: étape 1, image 3 de 3
    • Do not start this process until the laptop is unplugged and completely powered off.
    • Use the iFixit Opening Tool to pry open the screen.
  2. Lenovo ThinkPad T495s Screen Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T495s Screen Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    $3.99
    • Use the angled tweezers to lift the adhesive plastic above the connection.
  3. Lenovo ThinkPad T495s Screen Replacement: étape 3, image 1 de 3 Lenovo ThinkPad T495s Screen Replacement: étape 3, image 2 de 3 Lenovo ThinkPad T495s Screen Replacement: étape 3, image 3 de 3
    • To separate the display cable connector, gently wedge your opening tool under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
    • Pull in the direction of the cable to disconnect it.
Ijhanne Holder
Membre depuis le 03/28/22
431 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-7, Petersen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-7, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G7
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 56
Total : 908
