Aller au contenu principal
Lenovo ThinkPad X280  Fingerprint Scanner Replacement
Jordan Wooten
Jordan Wooten et 4 autres contributeurs
Dernière mise à jour le December 27, 2021
45 minutes - 1 heure
Modérée
This replacement guide will enable users to properly remove the fingerprint scanner on the Lenovo ThinkPad X280.
The fingerprint scanner is commonly used as an authentication device to grant users access to the device.
If your device’s sensor is dirty and failing to work properly, your device is unresponsive to your fingerprint, and/or fails to recognize your fingerprint, your fingerprint scanner may be insufficient.
It is important to note that typically only one finger can be used to relay an appropriate response from your device. Using multiple fingers can result in an ‘error’ or ‘fingerprint cannot be read’ message. In addition, in order to remove or replace the fingerprint scanner, you must first remove the battery.
Before consulting this guide, review this document for more solutions.
Ce dont vous avez besoin
Outils
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Back Panel: étape 1, image 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 3, image 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: étape 4, image 1 de 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: étape 4, image 2 de 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: étape 4, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: étape 5, image 1 de 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: étape 5, image 2 de 3 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: étape 5, image 3 de 3
    • Using a Phillips #1 screwdriver, remove one 5 mm screw from the fingerprint sensor.
    • Remove the metal plate covering the sensor.
  6. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 6, image 1 de 2 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 6, image 2 de 2
    • Using the black spudger tool, flip up the small hinged locking flap connected to the motherboard.
    • Gently pull the cable out of the connection site.
  7. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: étape 7, image 1 de 1
    • Remove fingerprint scanner and metal covering from device.
2 autres ont terminé cette réparation.
Jordan Wooten
Membre depuis le 09/05/21
615 Réputation
4 tutoriels rédigés
Équipe
University of Alabama, Team 1-3, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 1-3, Bedsole Fall 2021
UA-BEDSOLE-F21S1G3
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 23
Total : 1,522
