Lenovo ThinkPad X280 Motherboard Replacement
Introduction
Passez à l'étape 1Follow this guide to safely remove and replace the motherboard in your Lenovo ThinkPad X280. You may need to replace the motherboard if your laptop experiences hardware failure, such as no power, random shutdowns, or unresponsive components. Ensure you have the required tools and a compatible replacement motherboard before starting. This process involves disconnecting delicate internal components, so handle all connections and parts with care to avoid damage.
Ce dont vous avez besoin
Open the device to where you are directly viewing the screen with the keyboard laying flat.
Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
Remove the battery.
Push in with a SIM ejector tool, and while pushing, pull the tray out.
Use nails or a spudger to gently disconnect the first two plastic connectors from the motherboard by carefully pulling each one straight out of its socket.
Disconnect the power button (third picture) with a spudger by nudging it, alternating on right and left sides, until it can be pulled out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
