Aller au contenu principal
Lenovo ThinkPad X390 Battery Replacement
Curtis Kubacka
Curtis Kubacka et 2 autres contributeurs
Dernière mise à jour le May 18, 2024
7 - 10 minutes
Facile
Meilleure introduction
If you need to access your laptops trackpad, or need to replace your laptops battery please refer to this guide. This guide does not require any difficult or complicated steps. Do exercise caution before beginning this guide by ensuring that the laptop is unplugged and turned off. To complete the removal and/or the replacement of your battery, you will need a plastic opening tool, a Phillips #0 screwdriver, and a pair of tweezers.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad X390 Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Battery Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X390 Battery Replacement: étape 2, image 2 de 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Battery Replacement, Battery: étape 3, image 1 de 2 Lenovo ThinkPad X390 Battery Replacement, Battery: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
  4. Lenovo ThinkPad X390 Battery Replacement: étape 4, image 1 de 2 Lenovo ThinkPad X390 Battery Replacement: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
  5. Lenovo ThinkPad X390 Battery Replacement: étape 5, image 1 de 2 Lenovo ThinkPad X390 Battery Replacement: étape 5, image 2 de 2
    • Using your hands, remove the battery from the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 autres ont terminé cette réparation.
Curtis Kubacka
Membre depuis le 09/28/21
261 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 5-1, Hunter Fall 2021 Membre de l'équipe Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 membres
5 tutoriels rédigés
Un commentaire
Ich habe diesen Lenovo Thinkpad, jedoch einen ganz anderen Anschlußstecker des Akkus und keine Ahnung, wie ich den vom Rechner trennen kann.
Michael - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 107
30 derniers jours : 267
Total : 6,644
