Aller au contenu principal
Lenovo ThinkPad X395 SSD Replacement
Clay Eickemeyer
Clay Eickemeyer et 2 autres contributeurs
Dernière mise à jour le March 14, 2023
15 - 30 minutes
Facile
Follow this guide to replace or upgrade the Solid State Drive (SSD) in your ThinkPad X395. Note that a thermal pad helps the SSD dissipate heat more effectively. Remember to keep the original thermal pad, or have a replacement ready.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad X395 SSD Replacement, Loosen the back screws: étape 1, image 1 de 2 Lenovo ThinkPad X395 SSD Replacement, Loosen the back screws: étape 1, image 2 de 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 SSD Replacement, Release the clips: étape 2, image 1 de 2 Lenovo ThinkPad X395 SSD Replacement, Release the clips: étape 2, image 2 de 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 SSD Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X395 SSD Replacement: étape 3, image 2 de 2
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 SSD Replacement, Remove the back cover: étape 4, image 1 de 3 Lenovo ThinkPad X395 SSD Replacement, Remove the back cover: étape 4, image 2 de 3 Lenovo ThinkPad X395 SSD Replacement, Remove the back cover: étape 4, image 3 de 3
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
  5. Lenovo ThinkPad X395 SSD Replacement, Disconnect the battery cable: étape 5, image 1 de 2 Lenovo ThinkPad X395 SSD Replacement, Disconnect the battery cable: étape 5, image 2 de 2
    • Grab the battery pull-tab on the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad X395 SSD Replacement, Remove the SSD screw: étape 6, image 1 de 2 Lenovo ThinkPad X395 SSD Replacement, Remove the SSD screw: étape 6, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the 2.8 mm-long screw holding the SSD in place.
  7. Lenovo ThinkPad X395 SSD Replacement, Remove the SSD by hand: étape 7, image 1 de 3 Lenovo ThinkPad X395 SSD Replacement, Remove the SSD by hand: étape 7, image 2 de 3 Lenovo ThinkPad X395 SSD Replacement, Remove the SSD by hand: étape 7, image 3 de 3
    • Pull the SSD out and away from its socket.
    • If this motion requires excessive force, walk the SSD side to side as you pull.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
Membre depuis le 09/19/22
81 490 Réputation
455 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
9 membres
11 368 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 38
30 derniers jours : 175
Total : 5,070
