Aller au contenu principal
Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement
DistroHopper39B
DistroHopper39B et un autre contributeur
Dernière mise à jour le October 27, 2020
10 - 20 minutes
Facile
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
  1. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Battery: étape 1, image 1 de 1
    • Flip your laptop over.
    • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
  2. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Battery: étape 2, image 1 de 1
    • Pull the locking tab on the battery towards the unlock position.
    • Pull the battery out of the socket.
  3. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Bottom Cover: étape 3, image 1 de 1
    • Loosen the following five screws:
    • 5 Phillips #0 screws
    • 1 recessed Phillips #0 screw
    • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
  4. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Bottom Cover: étape 4, image 1 de 1
    • Pull up on the front cover from the left and right sides.
    • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
  5. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Hard Drive Caddy: étape 5, image 1 de 1
    • Slide the hard drive caddy to your left side using the pull tab.
    • Once it has been disconnected, pull up on the hard drive.
    • When reassembling, make sure to put the drive down before plugging it in. It might take some trial and error to get the drive seated properly.
  6. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement: étape 6, image 1 de 1
    • Remove all the Phillips #0 screws from the outside of the hard drive caddy.
    • Do not remove any of the screws from the top or bottom of the hard drive, as doing so can cause irreparable damage to the hard drive and the data on it.
  7. Lenovo Thinkpad Edge E40 Hard Drive/SSD Replacement, Hard Drive: étape 7, image 1 de 1
    • Separate the hard drive and the caddy.
Reinstall Windows or Linux on the new drive.
DistroHopper39B
Membre depuis le 05/30/20
414 Réputation
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 194
