Aller au contenu principal
Lenovo Thinkpad Edge E545 Screen Replacement
Maria Yepez
Maria Yepez et 4 autres contributeurs
Dernière mise à jour le January 5, 2021
10 minutes
Modérée
Étapes manquantes
If your Lenovo ThinkPad Edge E545 Laptop screen is not producing the correct visual display - cracks, discoloration, or a black screen - use this guide to replace the screen.
A working screen is very important to the function of a computer, it will allow the user to be able to see what they are doing and present necessary information. Without a working screen, the Lenovo ThinkPad Edge E545 will not be usable and will affect visual capabilities.
Before using this guide, inspect the perimeter of the screen for debris or cracks that may interfere with the removal of the screen. Additionally, inspect the battery on the bottom of the laptop for any debris that may interfere with its removal. Typically, a small buildup of dust can be removed with a small dust blower.
Step #5 asks you to use your finger to pry the display bezel to release the clips. Be careful in doing so that you do not hurt your fingers on the screen’s edges and do so gently to avoid any further damage to the screen.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Ce dont vous avez besoin
Outils
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Afficher plus…
  1. Lenovo Thinkpad Edge E545 Screen Replacement, Battery: étape 1, image 1 de 1
    • First, flip the laptop over as shown in the photo.
    • Make sure device is fully powered down before removing battery.
  2. Lenovo Thinkpad Edge E545 Screen Replacement: étape 2, image 1 de 1
    • Below the battery are two small tabs. These function as a lock for the battery.
    • Push the tabs towards each other to release the battery.
  3. Lenovo Thinkpad Edge E545 Screen Replacement: étape 3, image 1 de 1
    • Remove the battery from the device.
  4. Lenovo Thinkpad Edge E545 Screen Replacement, Screen: étape 4, image 1 de 2 Lenovo Thinkpad Edge E545 Screen Replacement, Screen: étape 4, image 2 de 2
    • Then, use the end of a spudger to remove the two screw covers from the top and bottom corners of the display.
  5. Lenovo Thinkpad Edge E545 Screen Replacement: étape 5, image 1 de 1
    • Slide your finger underneath the plastic and pry gently to release the clips around the display bezel.
  6. Lenovo Thinkpad Edge E545 Screen Replacement: étape 6, image 1 de 2 Lenovo Thinkpad Edge E545 Screen Replacement: étape 6, image 2 de 2
    • Lastly, peel up the adhesive tape to unbind the metal retaining bracket on the display cable.
Maria Yepez
Membre depuis le 10/24/18
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 672
