Aller au contenu principal
Lenovo Thinkpad T450s RAM Replacement
Hayden Hausman
Hayden Hausman et 3 autres contributeurs
Dernière mise à jour le July 22, 2019
5 minutes
Modérée
A besoin de meilleures images
If you are looking to replace/upgrade the RAM on your device follow this guide for step by step instructions on how to do so.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo Thinkpad T450s RAM Replacement, Battery: étape 1, image 1 de 2 Lenovo Thinkpad T450s RAM Replacement, Battery: étape 1, image 2 de 2
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s RAM Replacement: étape 2, image 1 de 1
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s RAM Replacement: étape 3, image 1 de 2 Lenovo Thinkpad T450s RAM Replacement: étape 3, image 2 de 2
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: étape 4, image 1 de 3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: étape 4, image 2 de 3 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: étape 4, image 3 de 3
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s RAM Replacement: étape 5, image 1 de 2 Lenovo Thinkpad T450s RAM Replacement: étape 5, image 2 de 2
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
    You don’t unscrew 8th screw a bit to the left from center of base where the battery sits?
    Thank you.
    Robert - Réponse
  6. Lenovo Thinkpad T450s RAM Replacement, RAM: étape 6, image 1 de 3 Lenovo Thinkpad T450s RAM Replacement, RAM: étape 6, image 2 de 3 Lenovo Thinkpad T450s RAM Replacement, RAM: étape 6, image 3 de 3
    • Pull one side of the prong that is holding the RAM in place
  7. Lenovo Thinkpad T450s RAM Replacement: étape 7, image 1 de 1
    • Pull the other side prong until the RAM pops up.
  8. Lenovo Thinkpad T450s RAM Replacement: étape 8, image 1 de 2 Lenovo Thinkpad T450s RAM Replacement: étape 8, image 2 de 2
    • Pull the RAM out of the device
Hayden Hausman
Membre depuis le 01/17/19
637 Réputation
6 tutoriels rédigés
1 commentaire de tutoriel
My t450s comes with an internal battery. The comment on this guide records the process for disabling the internal battery temporarily.
I also used this guide from Lenovo as I found removing the back plate rather difficult.
ray beats - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 22
Total : 5,086
