Aller au contenu principal
Lenovo V14-IIL Battery Replacement
K.Radford
K.Radford et 2 autres contributeurs
Dernière mise à jour le June 18, 2024
30 minutes
Facile
Étudiant en action
Battery degradation or damage can lead to the device not charging or not holding a charge. This guide shows how to replace the battery within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Ensure your charging brick and cable are functional and properly plugged in; if these steps work, you will not need to replace the battery.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Ce dont vous avez besoin
Outils
  1. Lenovo V14-IIL Battery Replacement, Back Panel: étape 1, image 1 de 2 Lenovo V14-IIL Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Battery Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Battery Replacement: étape 3, image 1 de 1
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Battery Replacement, Battery: étape 4, image 1 de 2 Lenovo V14-IIL Battery Replacement, Battery: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the three 5mm screws holding the battery.
  5. Lenovo V14-IIL Battery Replacement: étape 5, image 1 de 1
    • Detach the battery's cable connector from the laptop.
    • Lift out the battery.
K.Radford
Membre depuis le 01/30/24
324 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 21
Total : 222
