Aller au contenu principal
Lenovo V14-IIL LCD Screen Panel Replacement
Sydney Askins
Sydney Askins et 2 autres contributeurs
Dernière mise à jour le June 18, 2024
55 minutes
Modérée
Étudiant en action
Impact damage, water, overheating, and general wear and usage can cause the LCD panel to crack, develop missing pixels, or stop turning on. This guide shows how to replace the LCD panel within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo V14-IIL LCD Screen Panel Replacement, Back Panel: étape 1, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement, Back Panel: étape 1, image 2 de 2
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL LCD Screen Panel Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL LCD Screen Panel Replacement: étape 3, image 1 de 1
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL LCD Screen Panel Replacement, Display Assembly: étape 4, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement, Display Assembly: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL LCD Screen Panel Replacement: étape 5, image 1 de 1
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL LCD Screen Panel Replacement: étape 6, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement: étape 6, image 2 de 2
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL LCD Screen Panel Replacement: étape 7, image 1 de 1
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
  8. Lenovo V14-IIL LCD Screen Panel Replacement, Screen Bezel: étape 8, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement, Screen Bezel: étape 8, image 2 de 2
    • Slide the cable hinge cover to the right.
    • Pull the part away from the screen.
  9. Lenovo V14-IIL LCD Screen Panel Replacement: étape 9, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement: étape 9, image 2 de 2
    • Use the iFixit opening tool to separate the bezel panel.
    • Slide the opening tool all the way around to loosen the bezels on all sides.
    • You may need to use the tool to gently loosen the adhesive tape.
    • Lift away the bezel panel.
  10. Lenovo V14-IIL LCD Screen Panel Replacement, LCD Screen Panel: étape 10, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement, LCD Screen Panel: étape 10, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the six 2.2 mm screws from the hinges of the laptop.
    • Using a Phillips #0 screwdriver, remove the four 2.8 mm screws from the hinges and top corners of the laptop.
  11. Lenovo V14-IIL LCD Screen Panel Replacement: étape 11, image 1 de 2 Lenovo V14-IIL LCD Screen Panel Replacement: étape 11, image 2 de 2
    • Lift up the LCD panel and gently turn it over as though closing the lid.
  12. Lenovo V14-IIL LCD Screen Panel Replacement: étape 12, image 1 de 1
    • Lift the bracket securing the cable in place.
    • Gently pull the cable until it disconnects and lift away the old LCD panel.
Sydney Askins
Membre depuis le 01/16/24
378 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 193
