Aller au contenu principal
Mac mini Late 2018 Logic Board Assembly Replacement
Jeff Suovanen
Jeff Suovanen
Dernière mise à jour le November 29, 2020
Aucune estimation
Modérée
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Prerequisite-only guide to slide the logic board and attached components out of the Mac mini's chassis.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Mac mini Late 2018 Logic Board Assembly Replacement, Logic Board Assembly: étape 1, image 1 de 1
    • Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
  2. Mac mini Late 2018 Logic Board Assembly Replacement: étape 2, image 1 de 2 Mac mini Late 2018 Logic Board Assembly Replacement: étape 2, image 2 de 2
    • Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
    • Take care not to pry under the socket, or you may break it off the board.
  3. Mac mini Late 2018 Logic Board Assembly Replacement: étape 3, image 1 de 2 Mac mini Late 2018 Logic Board Assembly Replacement: étape 3, image 2 de 2
    • Use a T10 Torx driver to remove the two 7.5 mm screws securing the logic board.
  4. Mac mini Late 2018 Logic Board Assembly Replacement: étape 4, image 1 de 3 Mac mini Late 2018 Logic Board Assembly Replacement: étape 4, image 2 de 3 Mac mini Late 2018 Logic Board Assembly Replacement: étape 4, image 3 de 3
    • In this step, you'll push the logic board free from the clips holding it to the frame. Push only where directed or you may damage the fragile cooling fins.
    • Place a thumb at each end of the exhaust vent, over the fan screw holes.
    • Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
  5. Mac mini Late 2018 Logic Board Assembly Replacement: étape 5, image 1 de 2 Mac mini Late 2018 Logic Board Assembly Replacement: étape 5, image 2 de 2
    • Slide the logic board out of the case.
    • When reinstalling the logic board, make sure to hold the thin LED indicator light cable out of the way so it doesn't get damaged.
Jeff Suovanen
Membre depuis le 08/06/13
441 088 Réputation
259 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
120 membres
20 017 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 194
