Aller au contenu principal
Magic Bullet MB1001B Activator Replacement
Aubree Duran
Aubree Duran et 4 autres contributeurs
Dernière mise à jour le January 9, 2024
20 - 30 minutes
Modérée
Are you having trouble getting your Magic Bullet to turn on? Are the plastic activator tabs on your Magic Bullet broken off? This guide will help you replace the activators.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: étape 1, image 1 de 3 Magic Bullet MB1001B Activator Replacement, Base Gear: étape 1, image 2 de 3 Magic Bullet MB1001B Activator Replacement, Base Gear: étape 1, image 3 de 3
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
    Can you replace the base gear in a Mini Bullet? I am having a hard time unscrewing it.
    Margaret Bellanger - Réponse
  2. Magic Bullet MB1001B Activator Replacement, Casing: étape 2, image 1 de 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Activator Replacement: étape 3, image 1 de 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Activator Replacement: étape 4, image 1 de 1
    • Remove the black base plate.
  5. Magic Bullet MB1001B Activator Replacement: étape 5, image 1 de 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Activator Replacement: étape 6, image 1 de 1
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Activator Replacement: étape 7, image 1 de 1
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Activator Replacement: étape 8, image 1 de 1
    • Remove the black base.
  9. Magic Bullet MB1001B Activator Replacement: étape 9, image 1 de 1
    • Remove the three white rubber spacers with the spudger.
    White rubber spacer is broke from where to get one in colombon
    anonymous 1603 - Réponse
  10. Magic Bullet MB1001B Activator Replacement: étape 10, image 1 de 1
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
    How is called the cover held by the 3 screws? Can be bought somewhere?
    Nicolas All - Réponse
    will U give me feedback? If U have a part # will be great!
    Mine is broken, the rest is perfect! Thanks!
  11. Magic Bullet MB1001B Activator Replacement: étape 11, image 1 de 1
    • Remove the motor.
  12. Magic Bullet MB1001B Activator Replacement, Activator: étape 12, image 1 de 2 Magic Bullet MB1001B Activator Replacement, Activator: étape 12, image 2 de 2
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
    Do you know of anywhere to just buy the activator part for this machine? Thanks
    Izzi - Réponse
    Where can I buy the “white plastic activators”?
    Erick Mata-Montero - Réponse
3 autres ont terminé cette réparation.
Aubree Duran
Membre depuis le 10/06/15
387 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 12-13, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 membres
8 tutoriels rédigés
4 commentaires de tutoriel
You gotta be kidding me?
marcomolinero72 - Réponse
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - Réponse
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - Réponse
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 41
Total : 9,238
