Maingear Vector Laptop Screen Replacement
Ce dont vous avez besoin
pull off the black bezel around the deges
it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
Outil utilisé dans cette étape :Tweezers$4.99
carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
be careful not to rip the tape
the tape is in two vertical strips about an inch from the edge
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
