Aller au contenu principal
Makita DT01 LED light replacment
Ya'Rub Al Manwari
Ya'Rub Al Manwari et 5 autres contributeurs
Dernière mise à jour le December 18, 2023
25 - 45 minutes
Modérée
Texte bizarre
A besoin de meilleures images
Nécessite plus d'images
If your Makita DT01 light isn’t producing light or produces light that often flickers, use this guide to replace the LED.
The LED light produces light at the push of a button on the handle. A faulty LED will cause flickering light, much dimmer light than usual, or no light at all.
Before using this guide, inspect the light for any debris that could be preventing a properly working light from being usable. Typically, debris buildup can be wiped away with a Clorox wipe and paper towel, or use a soft cloth damp with warm water to wipe away the debris. Be sure to test the light again after cleaning to check if the debris or mechanical issue is causing the lack of light.
Step 3 requires you to reconnect the wires to the new LED. Make sure to use tweezers or similar tools to bend the wire into place once connected to the LED, otherwise, you could break or cause damage to the LED.
Ce dont vous avez besoin
Outils
  1. Makita DT01 LED light replacment, LED light: étape 1, image 1 de 2 Makita DT01 LED light replacment, LED light: étape 1, image 2 de 2
    • Take out the battery.
    • Unscrew the six screws in the top of the drill.
  2. Makita DT01 LED light replacment: étape 2, image 1 de 1
    • Motor and trigger should be separated.
    • The LED cable should be taken out from the trigger.
  3. Makita DT01 LED light replacment: étape 3, image 1 de 1
    • Take out the plastic tape that is stacked on the LED light.
    • Take out the two cables that are connecting with the LED light.
    • Reconnect the two cables again with the new LED light.
Ya'Rub Al Manwari
Membre depuis le 02/15/17
201 Réputation
2 tutoriels rédigés
1 commentaire de tutoriel
Where can I buy the replacement led?
Ciaran Moss - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 351
