Aller au contenu principal
Maze Speed SSB-508 Screen Replacement
Jun Soo Kim
Jun Soo Kim et 9 autres contributeurs
Dernière mise à jour le February 28, 2020
30 minutes
Très difficile
Étapes manquantes
This guide will show the process of replacing the glass screen of a Maze Speed phone. You will need a plastic opening tool, tweezers, iOpener, Phillips #00 Screwdriver, and soldering equipment. Soldering experience is beneficial in order to avoid damaging the phone’s other components. If the glass screen is cracked or shattered, you need to take extra precaution not to cut yourself.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Maze Speed SSB-508 Screen Replacement, Motherboard: étape 1, image 1 de 3 Maze Speed SSB-508 Screen Replacement, Motherboard: étape 1, image 2 de 3 Maze Speed SSB-508 Screen Replacement, Motherboard: étape 1, image 3 de 3
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed SSB-508 Screen Replacement: étape 2, image 1 de 2 Maze Speed SSB-508 Screen Replacement: étape 2, image 2 de 2
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed SSB-508 Screen Replacement: étape 3, image 1 de 3 Maze Speed SSB-508 Screen Replacement: étape 3, image 2 de 3 Maze Speed SSB-508 Screen Replacement: étape 3, image 3 de 3
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed SSB-508 Screen Replacement: étape 4, image 1 de 3 Maze Speed SSB-508 Screen Replacement: étape 4, image 2 de 3 Maze Speed SSB-508 Screen Replacement: étape 4, image 3 de 3
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed SSB-508 Screen Replacement: étape 5, image 1 de 2 Maze Speed SSB-508 Screen Replacement: étape 5, image 2 de 2
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed SSB-508 Screen Replacement: étape 6, image 1 de 2 Maze Speed SSB-508 Screen Replacement: étape 6, image 2 de 2
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed SSB-508 Screen Replacement: étape 7, image 1 de 3 Maze Speed SSB-508 Screen Replacement: étape 7, image 2 de 3 Maze Speed SSB-508 Screen Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed SSB-508 Screen Replacement: étape 8, image 1 de 2 Maze Speed SSB-508 Screen Replacement: étape 8, image 2 de 2
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed SSB-508 Screen Replacement: étape 9, image 1 de 1
    • Remove the motherboard from the back.
  10. Maze Speed SSB-508 Screen Replacement, Screen: étape 10, image 1 de 2 Maze Speed SSB-508 Screen Replacement, Screen: étape 10, image 2 de 2
    • Apply the heated iOpener to all sides of the screen (left, right, top, and bottom) for 90 seconds (or more if necessary) to soften the adhesive.
  11. Maze Speed SSB-508 Screen Replacement: étape 11, image 1 de 3 Maze Speed SSB-508 Screen Replacement: étape 11, image 2 de 3 Maze Speed SSB-508 Screen Replacement: étape 11, image 3 de 3
    • Use a Jimmy's flexible steel blade to separate the screen from the frame. Insert the blade between the frame and screen then carefully lift using the blade.
    • Gently lift the glass screen and remove from the frame.
  12. Maze Speed SSB-508 Screen Replacement: étape 12, image 1 de 3 Maze Speed SSB-508 Screen Replacement: étape 12, image 2 de 3 Maze Speed SSB-508 Screen Replacement: étape 12, image 3 de 3
    • There will be a thin flat cable at the top of the screen in which you need to carefully peel back.
  13. Maze Speed SSB-508 Screen Replacement: étape 13, image 1 de 1
    • Move the connecting wire through the hole at the top frame.
    • Then, remove the glass screen and replace with the new one.
To reassemble your device, follow these instructions carefully in reverse order.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,017
