Aller au contenu principal
Microsoft Zune 30 GB Battery Replacement
jmorri04
jmorri04 et 16 autres contributeurs
Dernière mise à jour le May 23, 2016
5 minutes
Facile
Remove the ribbon cable that attaches the battery to the logic board. If the brown latch is lifted too high it will detach and the white piece might fall off during later steps.
Ce dont vous avez besoin
  1. Microsoft Zune 30 GB Battery Replacement, Back Case: étape 1, image 1 de 2 Microsoft Zune 30 GB Battery Replacement, Back Case: étape 1, image 2 de 2
    • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
    • Be gentle when removing the screw cover as it is brittle and will break if forced.
    • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
    The piece extends inward to kind of sheath the connector itself so it takes a little back and forth between the sides.
    jonathan - Réponse
    Also important to note that this piece only goes in one way, so take note of its orientation, and don't force it if it isn't sliding back in.
    kazoodac - Réponse
  2. Microsoft Zune 30 GB Battery Replacement: étape 2, image 1 de 1
    • Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Be gentle when prying the device open.
  3. Microsoft Zune 30 GB Battery Replacement: étape 3, image 1 de 2 Microsoft Zune 30 GB Battery Replacement: étape 3, image 2 de 2
    • Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
    • The battery is not fastened to the inside of the case. It will fall out.
    • Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
    • The case is now separated. You can replace the case, if needed.
    The battery flopping out definitely surprised me a bit.
    jonathan - Réponse
  4. Microsoft Zune 30 GB Battery Replacement, Battery: étape 4, image 1 de 2 Microsoft Zune 30 GB Battery Replacement, Battery: étape 4, image 2 de 2
    • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
    • Use the small flat head screw driver to gently lift the brown clamp.
    • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
  5. Microsoft Zune 30 GB Battery Replacement: étape 5, image 1 de 1
    • You can now replace the battery.
    • The battery is a Lithium ion 3.7 V.
21 autres ont terminé cette réparation.
jmorri04
Membre depuis le 10/16/09
308 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 19-4, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 19-4, Maness Fall 2009
CPSU-MANESS-F09S19G4
3 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Someone please send a link for a new battery. Thanks
Earl - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 35
30 derniers jours : 143
Total : 18,387
