Aller au contenu principal
Motorola Moto E4 Motherboard Replacement
Nate Tjepkema
Nate Tjepkema et 6 autres contributeurs
Dernière mise à jour le May 7, 2024
15 minutes
Modérée
Use this guide to remove or replace the Moto E4 motherboard.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Ce dont vous avez besoin
Outils
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Afficher plus…
  1. Motorola Moto E4 Motherboard Replacement, Remove the rear cover: étape 1, image 1 de 2 Motorola Moto E4 Motherboard Replacement, Remove the rear cover: étape 1, image 2 de 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Replacement, Remove the motherboard cover: étape 2, image 1 de 2 Motorola Moto E4 Motherboard Replacement, Remove the motherboard cover: étape 2, image 2 de 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Motherboard Replacement: étape 3, image 1 de 2 Motorola Moto E4 Motherboard Replacement: étape 3, image 2 de 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Motherboard Replacement: étape 4, image 1 de 3 Motorola Moto E4 Motherboard Replacement: étape 4, image 2 de 3 Motorola Moto E4 Motherboard Replacement: étape 4, image 3 de 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
  5. Motorola Moto E4 Motherboard Replacement, Remove the motherboard: étape 5, image 1 de 2 Motorola Moto E4 Motherboard Replacement, Remove the motherboard: étape 5, image 2 de 2
    • Disconnect the display cable by prying it straight up from the motherboard.
  6. Motorola Moto E4 Motherboard Replacement: étape 6, image 1 de 2 Motorola Moto E4 Motherboard Replacement: étape 6, image 2 de 2
    • Unlock the ZIF connector for the side buttons by prying up the black locking flap opposite the cable.
    • Pull the cable carefully toward the edge of the phone to slide it from its socket.
  7. Motorola Moto E4 Motherboard Replacement: étape 7, image 1 de 2 Motorola Moto E4 Motherboard Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Disconnect the antenna cable by sliding a plastic pry tool or fine tweezers under the wire close to its socket, and then prying straight up.
  8. Motorola Moto E4 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the two 3.1 mm long Phillips screws securing the motherboard.
  9. Motorola Moto E4 Motherboard Replacement: étape 9, image 1 de 2 Motorola Moto E4 Motherboard Replacement: étape 9, image 2 de 2
    • Grab the top edge of the motherboard and lift to hinge it upward (but don't try to fully remove it). While doing so, keep all other cables clear of the motherboard.
    • Use a spudger or other fine-tip pry tool to pry off and disconnect the last remaining ribbon cable on the underside of the motherboard.
    • Remove the Moto E4 motherboard.
6 autres ont terminé cette réparation.
Nate Tjepkema
Membre depuis le 01/24/19
1 254 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S2-G4, White Winter 2019 Membre de l'équipe Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 membres
22 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 26
Total : 2,991
