Aller au contenu principal
Mr. Coffee BVMC-SJX33GT Heating Plate Replacement
Mackenzie Aiken
Mackenzie Aiken et un autre contributeur
Dernière mise à jour le June 23, 2015
15 - 20 minutes
Facile
This guide to replace the heating plate of the Mr. Coffee BVMC-SJX33GT will be particularly useful if the heating plate your carafe sits on burns or corrodes in some way.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Base: étape 1, image 1 de 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 2, image 1 de 2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 2, image 2 de 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, security screws: étape 3, image 1 de 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 4, image 1 de 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Rubber Hose: étape 5, image 1 de 3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Rubber Hose: étape 5, image 2 de 3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Rubber Hose: étape 5, image 3 de 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
    Where do you get replacement hoses?
    Tom Hanig - Réponse
    How to get replace hoses
    Ronnie Anderson -
    Ok I cleaned mine the way you are supposed to, but it is still brewing super slow.
    Marlene - Réponse
    Food grade silicone tubing Amazon Smile link https://smile.amazon.com/Univen-High-Gra...
    Brian Comly - Réponse
  6. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 6, image 1 de 3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 6, image 2 de 3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 6, image 3 de 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 7, image 1 de 2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 7, image 2 de 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 8, image 1 de 2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 8, image 2 de 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 9, image 1 de 2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 9, image 2 de 2
    • Grip the hoses and pull them straight up and out.
    I have the same coffee maker as pictured. I removed the clamps, and the first hose came off easily. The hose housing the valve would not come loose. I ended up tearing the hose while trying. Any ideas for a replacement hose? And how to get this torn one off?
    Brianna Singh - Réponse
    Sadly, you mentioned the size of the screws, but failed to mention the most important piece of information, the size of the actual silicone hose (ID & OD).
    K T - Réponse
    Very helpful procedure. All 7 screws on my maker were Philips heads so thankfully did not need that special tool. As I did not have a spare valve, I ran water through mine and confirmed the operation of the valve by blowing on each side. The valve seems clear and working as it should but after reassembly sadly it made no difference. I think in my case there must be something wrong with the heater circuitry and will have to dig a bit deeper to determine what failed and if it is worth (or even possible) to replace the defective part.
    Ron Biegel - Réponse
  10. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Heating Plate: étape 10, image 1 de 3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Heating Plate: étape 10, image 2 de 3 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement, Heating Plate: étape 10, image 3 de 3
    • Locate the two 17mm screws securing the bracing bar.
    • Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
    Note that a common failure point in this kind of appliance is the thermal fuse, seen in the above photo as the electronics-looking thing in the photo above, connected to the blue wire. If the coffee pot will not heat at all, check this fuse with a multimeter to see if it’s blown. It could save you the frustration of a replacement heating element that does not solve the problem.
    Dave - Réponse
  11. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 11, image 1 de 2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 11, image 2 de 2
    • Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
    • Set the metal tubing aside.
  12. Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 12, image 1 de 2 Mr. Coffee BVMC-SJX33GT Heating Plate Replacement: étape 12, image 2 de 2
    • Push the heating plate up from below and remove.
    Thank you for the article. However, you forgot to mention what to do about the thermal compound that is applied to the underside of the warming plate. If the appliance is an older model, the thermal paste will have dried and cracked. A lot of it will probably fall off. This paste is crucial for transferring heat from the heating element to the warming plate. It is similar to the paste used when mounting CPUs to a motherboard. I'm trying to find jars of it instead of the little tubes, which would require 1-2 tubes to do it right. Anyway, I hope this helps. Thanks again for the article!
    Greg
    Bonzo - Réponse
3 autres ont terminé cette réparation.
Mackenzie Aiken
Membre depuis le 01/27/15
1 500 Réputation
6 tutoriels rédigés
Équipe
San Diego State, Team 1-4, Sheppard Winter 2015 Membre de l'équipe San Diego State, Team 1-4, Sheppard Winter 2015
SDSU-SHEPPARD-W15S1G4
2 membres
6 tutoriels rédigés
6 commentaires de tutoriel
I need to know which of the various high-heat thermal paste should be used that will maintain re-bonding the heating tube to the heating plate. The manufacturer did not use thermal grease as it appears it will not maintain the bond between the heating tube and the heating element. They instead used a vertically stable paste that assumes a hardened consistency of chalk to best maintain the bond in the presence of water. However, I have yet to find the proper paste which bonds while tolerating the sufficient intermittent high heat ratings required. The manufacturer has been unable to provide any assistance or information. Can you please tell me what material to use in this circumstance. Thanks KB.
K B - Réponse
I am unfortunately unaware of the answer to this question. I hope someone else can answer it.
Mackenzie Aiken -
The two inline thermal fuses (brass cylinders with a black end) are far more likely to fail than the heating element. Check them first.
T99 or Super Lube
3 oz. Tube Heat Sink Compound
can be used with the heater.
gdrgry34fsdf324 - Réponse
Where can I obtain the heating plate? The coating has burned off and now rust corrosion has to scrubbed off after every use (including off the glass pot!!). Thanks.
B Welkinator - Réponse
Liked to video. Thanks for posting. Where can I purchase the black metal heating plate for Oster coffee maker or any maker?
Stephanie Gross - Réponse
First, you don't need to remove the water tubes to remove the hot plate. Second, you don't need to worry about gluing the hot plate back together with the hot element. Once you screw down the cross-bar, the hot plate will be secure, no need to glue the plate! Regarding this metal hot plate disc, I have not found any replacement disc for my Mr. Coffee maker, anywhere. After sanding and cleaning the disc, I painted it with multiple coats of Rust-Oleum primer and paint (Red). I now believe that I can replace the metal disc with a glass disc. The glass disc can handle up to 400 degrees Freiheit. The coffee maker's disc only gets up to around 200 degrees Freiheit. I will be buying the round Borosilicate 4 1/4 inch glass disc from mcmaster.com
Anthony Rivers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 61
Total : 6,022
