Aller au contenu principal
Nikon Coolpix P90 Motherboard Replacement
Elizabeth Kamine
Elizabeth Kamine et 6 autres contributeurs
Dernière mise à jour le January 20, 2025
15 - 30 minutes
Difficile
A besoin de meilleures images
If the camera powers on but does not function properly (refuses to take pictures, fails to navigate the memory card, prevents access to settings, etc.), you may need to replace the motherboard.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Nikon Coolpix P90 Motherboard Replacement, Camera Base: étape 1, image 1 de 3 Nikon Coolpix P90 Motherboard Replacement, Camera Base: étape 1, image 2 de 3 Nikon Coolpix P90 Motherboard Replacement, Camera Base: étape 1, image 3 de 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Motherboard Replacement, Motherboard: étape 2, image 1 de 3 Nikon Coolpix P90 Motherboard Replacement, Motherboard: étape 2, image 2 de 3 Nikon Coolpix P90 Motherboard Replacement, Motherboard: étape 2, image 3 de 3
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • Remove both 4.5 mm screws holding the bottom into place.
    • Remove both 4.5 mm screws holding the side into place.
    • Remove the 4.5 mm screw underneath the A/V flap.
    • Remove the 4.0 mm screw on the left-side wrist strap loop.
  3. Nikon Coolpix P90 Motherboard Replacement: étape 3, image 1 de 3 Nikon Coolpix P90 Motherboard Replacement: étape 3, image 2 de 3 Nikon Coolpix P90 Motherboard Replacement: étape 3, image 3 de 3
    • Carefully lift the back cover from the camera.
    • Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard.
  4. Nikon Coolpix P90 Motherboard Replacement: étape 4, image 1 de 2 Nikon Coolpix P90 Motherboard Replacement: étape 4, image 2 de 2
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon.
    • Be careful when releasing the safety latch because it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
    Can a torn ribbon be fixed?
    Edgar Ramirez - Réponse
  5. Nikon Coolpix P90 Motherboard Replacement: étape 5, image 1 de 2 Nikon Coolpix P90 Motherboard Replacement: étape 5, image 2 de 2
    • Remove the seven 4.0 mm screws that connect the metal plate to the motherboard.
    • Remove the three 4.0 mm screws that connect the metal hinges to the camera body.
  6. Nikon Coolpix P90 Motherboard Replacement: étape 6, image 1 de 1
    • Carefully lift the metal backing from the motherboard.
    • Do NOT completely remove the metal backing yet. There is a data transfer ribbon connecting the metal backing to the motherboard.
  7. Nikon Coolpix P90 Motherboard Replacement: étape 7, image 1 de 2 Nikon Coolpix P90 Motherboard Replacement: étape 7, image 2 de 2
    • It is now safe to completely remove the metal backing from the camera.
  8. Nikon Coolpix P90 Motherboard Replacement: étape 8, image 1 de 1
    • Using a Phillips #000 Precision Screwdriver, remove the three 3.0 mm screws from the motherboard.
  9. Nikon Coolpix P90 Motherboard Replacement: étape 9, image 1 de 1
    • Press your finger on the top of the latches and pull them down and toward you to open the safety latches and free the five data transfer ribbons.
    • Be careful when releasing the safety latches because they are fragile and may break easily.
    • Slide the five ribbons out from their sockets.
  10. Nikon Coolpix P90 Motherboard Replacement: étape 10, image 1 de 2 Nikon Coolpix P90 Motherboard Replacement: étape 10, image 2 de 2
    • Desolder the wires to fully disconnect the motherboard from the camera.
    • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
    • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
Elizabeth Kamine
Membre depuis le 01/22/15
655 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-14, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 membres
7 tutoriels rédigés
2 commentaires de tutoriel
By the way on step 10, you show the soldering iron right beside the "RD" red wire near top middle which should be discharged before you get the shitfuckpiss scared out of you and drop your soldering iron in your lap. There's gotta be several thousand volts on that connection, I discharged it with alligator clips to ground after going through my fingers a couple times (before finding which one it was) about 6 times and it was extremely bright and loud. PS. My arm is numb at least to my elbows on this one! ...and I might need a new pair of pants, from either the $@$*, !#^&, or soldering iron. :(
Xexorian - Réponse
Can a torn ribbon be fixed??
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 1,609
