Aller au contenu principal
PowerA Enhanced Wireless Controller L and R buttons Replacement
Ayjah Montgomery
Ayjah Montgomery et 6 autres contributeurs
Dernière mise à jour le May 7, 2024
5 - 10 minutes
Modérée
If you've been experiencing issues with the functionality of your L and R buttons while using your PowerA Enhanced Wireless Controller for Nintendo Switch, you're not alone. These buttons are crucial to the operation of the controller and can often become less responsive over time due to wear and tear. This guide will walk you through the necessary steps to access and replace or clean these buttons, restoring your controller to peak performance.
This repair will address common issues such as marginal response of the L and R buttons, L and R buttons sticking due to dust or residue build up and/or physical damage on the L and R buttons.
Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any potential issues with the motherboard. Step 1 of this guide will show you how to access the battery compartment.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: étape 1, image 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: étape 1, image 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: étape 1, image 3 de 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 2, image 1 de 1
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 3, image 1 de 2 PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 3, image 2 de 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 4, image 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 4, image 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 4, image 3 de 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: étape 5, image 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: étape 5, image 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: étape 5, image 3 de 3
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 6, image 1 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 6, image 2 de 3 PowerA Enhanced Wireless Controller L and R buttons Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
Ayjah Montgomery
Membre depuis le 10/10/19
408 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 membres
11 tutoriels rédigés
2 commentaires de tutoriel
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - Réponse
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 11
30 derniers jours : 67
Total : 3,629
