PowerBook G4 Titanium DVI Hard Drive Replacement
Introduction
Passez à l'étape 1You can install hard drives up to 12.5mm thick.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
45 autres ont terminé cette réparation.
Pièces jointes
3 commentaires de tutoriel
Easy to do; I have upgraded my Titanium 15 several times and it last ran from a 320gB HDD very successfully. Then it fell off my sofa just once too often... :-(
Oh well, after nine solid years of totally fault-free service (eat ya heart out Mr. Pee Cee!) it will be good for parts and may live on yet.
Beware, Step 4 is missing a crucial piece of information!
There's a little black plastic piece on the right side, secured with two hex screws, that needs to be taken out before lifting the drive.
