Aller au contenu principal
PowerShot G7 X Mark II Front Cover Replacement
Brandon
Brandon et 2 autres contributeurs
Dernière mise à jour le May 25, 2017
40 - 55 minutes
Modérée
Photos d’action
A besoin de meilleures images
This guide will show you how to replace the Front Panel and Focus Ring of the camera if it is damaged or if the lens has gotten dirt lodged in it.
Ce dont vous avez besoin
Outils
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: étape 1, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: étape 1, image 2 de 2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: étape 2, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 2, image 2 de 2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: étape 3, image 1 de 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: étape 4, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 4, image 2 de 2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: étape 5, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 5, image 2 de 2
    • Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
    • If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
  6. PowerShot G7 X Mark II Front Cover Replacement: étape 6, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: étape 7, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 7, image 2 de 2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 1 de 3 PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 2 de 3 PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 3 de 3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: étape 9, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 9, image 2 de 2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: étape 10, image 1 de 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: étape 11, image 1 de 1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: étape 12, image 1 de 1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
2 autres ont terminé cette réparation.
Brandon
Membre depuis le 02/15/17
626 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 12-3, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 membres
4 tutoriels rédigés
2 commentaires
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Réponse
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 34
Total : 4,314
