Aller au contenu principal
Princess Croque Monsieur Thermal Fuse Replacement
Merijn van Niekerk
Merijn van Niekerk et 2 autres contributeurs
Dernière mise à jour le May 13, 2019
30 minutes
Modérée
Thermal fuses are the most common part in a toaster that stop working. When a toaster machine stops working, people usually throw it away and buy a new one. however, the problem is really simple to fix, and is way cheaper than buying a new Croque Monsieur-/panini press. We are going to show you how.
  1. Princess Croque Monsieur Thermal Fuse Replacement, Thermal Fuse: étape 1, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement, Thermal Fuse: étape 1, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement, Thermal Fuse: étape 1, image 3 de 3
    • Pull the plug of the panini press the out of the socket.
    • Unclip the black 'closing part' and open the toaster.
  2. Princess Croque Monsieur Thermal Fuse Replacement: étape 2, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 2, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 2, image 3 de 3
    • Remove the screws of the front plate, by using a Philips #1 Screwdriver
  3. Princess Croque Monsieur Thermal Fuse Replacement: étape 3, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 3, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 3, image 3 de 3
    • Remove the front plate as shown on the picture.
    • Remove the screws of the top plate, the same way you did at the bottom (see step 2).
    • Remove the top plate as shown in the picture.
  4. Princess Croque Monsieur Thermal Fuse Replacement: étape 4, image 1 de 2 Princess Croque Monsieur Thermal Fuse Replacement: étape 4, image 2 de 2
    • Remove the two screws at the back of the heating plate as shown in the pictures.
  5. Princess Croque Monsieur Thermal Fuse Replacement: étape 5, image 1 de 2 Princess Croque Monsieur Thermal Fuse Replacement: étape 5, image 2 de 2
    • Turn the panini press around to be able to reach the screws of the other heating panel. and remove these screws the same way you did at the bottom side (step 4).
    • Place the panini press such that you can easily look under the heating elements (as seen in the second picture).
  6. Princess Croque Monsieur Thermal Fuse Replacement: étape 6, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 6, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 6, image 3 de 3
    • The thermal fuse is placed at the top part of the panini press.
    • The fuser is covered by a white 'rope-like sleeve'.
    • you can reach the fuser by removing the screw in the middle, using the screwdriver.
  7. Princess Croque Monsieur Thermal Fuse Replacement: étape 7, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 7, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 7, image 3 de 3
    • Move the rope-like sleeve to the left side to reach the thermal fuse.
    • Remove the black 'rope' so you can cut the wire, using the wire cutter.
  8. Princess Croque Monsieur Thermal Fuse Replacement: étape 8, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 8, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 8, image 3 de 3
    • Cut the wire as shown in the picture.
    • Remove the white sleeve and cut the other side of the fuse.
  9. Princess Croque Monsieur Thermal Fuse Replacement: étape 9, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 9, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 9, image 3 de 3
    • Solder the new thermal fuser on the cable, using the soldering machine.
    • Slide the 'rope-like sleeve' on the cable until the fuser sticks through the other side.
    don't solder the fuse back on the cable. It will ruin the temperature-controlled fuse!
    Bas Flipsen - Réponse
  10. Princess Croque Monsieur Thermal Fuse Replacement: étape 10, image 1 de 2 Princess Croque Monsieur Thermal Fuse Replacement: étape 10, image 2 de 2
    • Solder the other part on to the red cable as shown in the picture.
    • Slide the sleeve over the fuse as it was before you had cut the fuse (if you don't remember how it needs to be, just go back to the picture in step 6).
  11. Princess Croque Monsieur Thermal Fuse Replacement: étape 11, image 1 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 11, image 2 de 3 Princess Croque Monsieur Thermal Fuse Replacement: étape 11, image 3 de 3
    • Reassemble the panini press by following the steps in reverse.
Merijn van Niekerk
Membre depuis le 12/05/16
101 Réputation
1 tutoriel rédigé
Un commentaire
Don't solder the fuse to the cables because they are temperature-controlled fuses. When using a hot soldering iron, the fuse will break down again!
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 376
